Error when converting NURBS to Arcs
when converting to arcs the curve in the example file attached one part of the curve is lost. Is there any parameter that we can tweek to achieve a correct conversion or is this an issue?
Thanks a lot,
Alberto
Launch 01-Errore.3dm (134.3 KB)
Hi Alberto - this seemed to work OK here:
Launch 01-Errore_PG.3dm (151.1 KB)
Thanks Pascal! Is the curve I get out an error or a problem with tolerances? I mean, why does it skip that part when the tolerance is lower? The settings I am using are:
