Error when applying PreDrawObjects
Hi guys,
While trying to add lines in PreDrawObjects of conduit class I have noticed that some lines are missing when you try to rotate the view.
When declaring the conduit - I am joining all the bounding boxes of the lines into one bounding box (m_bbox) which is used later in the following sub:
Protected Overrides Sub CalculateBoundingBox(e As Rhino.Display.CalculateBoundingBoxEventArgs)
      MyBase.CalculateBoundingBox(e)
      e.BoundingBox.Union(m_bbox)
End Sub
So, what can be the problem?
Thanks in advance!
Kind regards,
Dmitriy
It seems that i fixed the problem by using IncludeBoundingBox method.
However would like to know what is the difference between IncludeBoundingBox and Union methods.
Thanks,
Dmitriy
The problem with Union is that it is working on a value class and therefore that value is not getting set back on the eventargs
Thanks, David
Now it is clear.
