Hi! I`m having an error when applying color, (so the gradient should go from the peaks down, like the other image, but in the current model it is like out of scale looks more like stripes.
formfinding5.gh (32.0 KB)
This is how you should set gradients based on peaks/ heights. And there is some issue with Kangaroo modeling once you solve it. This method works as well as your second reference image.
Cheers,
BVR
I want to add that that might be the appropriate way how to use the gradient but won’t color local min/max points on a spherical mesh.
Easiest would be using spherical coordinates & use the radial distance for coloring. Or Vector length between before & after simulation point position.
