Hello
I’ve been trying to uplad a gh definition, but only certain meshes are visible on shapediver
Can anyone help me to understand what’s wrong
regards
mario
phonr.gh (668.8 KB)
Hello
regards
mario
phonr.gh (668.8 KB)
My apologies for the late answer. I opened your definition in Rhino and then uploaded it to ShapeDiver and I get identical results in both environments.
In Grasshopper, your initial Offset Curve component fails to produce results because it is missing a plane input:
I would also consider it risky to provide a hardcoded negative offset because the curve orientation might depend on rhino versions. It is always a good idea to do a sanity check of the outputs when doing this type of operations.
I hope that helps.
