Hi all,
Hope you’re all doing well, this is my first post on this forum! I’m having trouble with the Heteroptera plugin and its “Network from Lines” component. The first time I used it, it worked perfectly fine - I’m using it to generate network information from Voronoi created cells and analyzing line connections post using the Sandbox plugin tools. However, after using it once, trying to use it for different data trees I get the readout error of “Solution Exception: An item with the same key has already been added”. This error does not clear after deleting the component, removing/adding it, or copying it to a new sheet.
Does anyone have any ideas on how this can be overcome? I tried clearing and recomputing the grasshopper files with no luck.
Thank you!
