Your first Data component has 2496 values in branches of two, meaning 1248 pairs. You graft it and you get 2496 branches of single values.
The second Data component features 1248 single values in individual branches.
Since you have your Python component inputs set to List Input, this means that the code inside the component is run for each individual branch of the tree, since each branch is a list. Now you’re left 2496 values to pair with 1248 values which is problematic, since only half of the 2496 values have a corresponding value.
As you can see the component runs 2495 cycles starting from 0, which translated to running the code 2496 times.
If at each cycle you want to process a pair of values from the first Data component with a single value from the second Data component simply don’t graft the first one!
Now the component runs 1247 cycles starting at 0, which seems more appropriate.
Since you know that at each cycle, two values of x_in and one value of y_in get evaluated together, you have to refactor your code to something like this:
a = []
xran = (100, 120, 140, 160, 180, 200, 210, 220, 230, 240, 250, 260, 270, 280, 300)
xres = [(97,108,119,129,140,150,160,170,180,190,200,210,220,230,240,251,276,301), # 48
(97,108,119,129,140,150,160,170,180,190,200,210,220,230,240,251,276,301), # 60
(120,132,143,154,165,176,181,186,191,196,202,207,212,217,227), # 76
(127,140,152,163,174,185,190,195,200,206,211,216,221,226,237), # 89
(134,145,156,167,178,189,199,209,220,230,240,250,261,271,281,291,316,341), # 102
(129,140,152,163,174,185,195,205,216,226,237,247,257,267,277,287,313,338), # 114
(181,195,208,219,229,241,252,263,273,284,294,304,315,325,335,345,371,396), # 133
(173,189,203,215,227,238,250,261,271,282,292,303,313,324,334,344,370,395), # 159
(253,253,253,253,267,279,292,303,315,326,337,348,359,369,380,390,416,442), # 219
(357,357,357,357,357,357,357,357,357,357,370,383,394,406,418,429,456,483), # 245
(357,357,357,357,357,357,357,357,357,357,370,383,394,406,418,429,456,483), # 273
(430,430,430,430,430,430,430,430,430,430,430,430,430,430,442,455,484,513)] # 325
yran = [48,60,76,89,102,114,133,159,219,245,273,325]
y = y_in[0]
for x in x_in:
res = 500
if y in yran:
idx_y = yran.index(y)
if x in xran:
idx_x = xran.index(x)
res = xres[idx_y][idx_x]
a.append(res)
if_else error-rev.gh (25.1 KB)
