Error on Rhino 8?
When I select surfaces of my model,
some randomly mixed colors appears and it bothers me…
It’s been starting since I update from 7 to rhino 8.
Is there anyone who already solved the same issue?
It’d help if you posted the results of the Rhino command _SystemInfo.
those look like reflections of a background setting, i’ve seen similiar when i’ve had funky things in my models. What is the material/display setting of your surfaces. Set all to by layer and use a default material for the layer, and go to standard shaded view with single color background.
post results.
