In the blockmanager I have a lot of messages like this:
Is this a problem? Shut or can I delete this blocks?
Best regards.
Hi Simon,
Do you have some referenced block in that model? Looks like it doesn’t find some VisualARQ objects included in those block definitions. If you use referenced blocks that contain VisualARQ objects, make sure you use the “embedded and linked” option. If the problem is different, please send us that file to visualarq@asuni.com and we will check it out.
Best regards,
