Hi
I am total newbie
I am trying to make a script that copy several objects and then add a surfix to the name.
Right now I just made a small script to print the objects name.
But when I do run it it get this error:
name required when object_id represents multiple objects
Can anybody help make the script work
Here is the script for print names:
obj =rs.GetObjects()
names = rs.ObjectName(obj)
print names
Hope someone will help me
GetObjects() allows one to pick multiple objects and thus returns a list (even if it’s a list of just one item).
ObjectName() accepts only one object, not a list. So you will need to loop through the list returned by GetObjects() and feed the list members to ObjectName() one at a time.
Example:
objs=rs.GetObjects()
#this is your loop
for obj in objs:
obj_name=rs.ObjectName(obj)
print obj_name
#you could do something else with the object name, i.e. add a suffix, etc.
There is no error checking in the above, it does not check if any objects have actually been selected by GetObjects() or if the selected objects have a name. That would need to be added.
Thanks !
I have succesful got a list with names. However when I add a surfix to the objects name, it only add the surfix to the last name in the list.
Got any advise for how to overcome this ?
naming_help.py (457 Bytes)
That’s kind of a confusing script. I might do it this way:
objs =rs.GetObjects()
if objs:
#are you really wanting to create copies of the objects?
copies = rs.CopyObjects(objs)
mb1 = rs.MessageBox("Add suffix?", 4)
if mb1 ==6:
#can also ask the user for suffix via rs.StringBox()
suffix="-suffix"
#create a counter for objects that have names
named_obj_count=0
#now run your loop
for obj in copies:
if obj_name:
#means the object had a name, add suffix
new_name=rs.ObjectName(obj,obj_name+suffix)
#increment the counter
named_obj_count+=1
#reporting
if named_obj_count==0:
#no objects had names
msg="No named objects found"
else:
msg="Added suffixes to {} objects".format(named_obj_count)
#the format statement inserts the counter value inside the brackets
print msg
Feel free to ask questions on the procedure if there is something you don’t understand.
