Error message when using ExportLayerObjects script
OK, I see it - I’ll fix that.
@tntndi001 - please replace the previous file with this one. It should work better for non-3dm files. You will see error messages if, for excample, meshes are exported as stp - this is not supported so you’ll have to dismiss the warning message for these objects, but the script will continue. It’s possible to work around this in the script but as is there is no check for object types.
ExportLayerObjects_PG.rvb (3.0 KB)
