Error Message: Unable to add line to document
hi
Why do I give this error when I want to draw a line between two points?3a.py|attachment (379 Bytes)
Hi @arefeepaydar ,
rs.AddLine() takes Guid as arguments, which means you don’t have to coerce.
in Your case
line = rs.AddLine(pt1,move)
tanks
But the code gave an error again:((((
pt1=rs.GetPoint("Pick a point")
#create a vector
vec=rs.coerce3dvector([10,0,0])
#add the vector to the point to create a new point
pt2=pt1+vec
# create a line between the original and the new point
line_id=rs.AddLine(pt1,pt2)
You can also do it like this:
#create a vector
#add the vector to the point and create a line directly
line_id=rs.AddLine(pt1,pt1+vec)
Hi
Thank you so much:))))
