Hello. I get this message upon opening any Rhino file. I click remove, save, etc. but if I save and close the file, it appears again when opening the file. I tried to download the file but it didn’t work. I searched for the file “brushed.jpg” and it isn’t anywhere. Any ideas?? It happens with opening ALL files.
hi @Karen_C If you select the material, then click Edit… And select the texture in the material, what is the location of the texture it tries to search for?
Thanks for the quick reply!
It gives me a location but it doesn’t exist (see screenshot) and tells me that the plug in is not loaded. I have searched all of the material files and brushed.jpg doesn’t exist in any of my folders.
I was able to get the error message to stop popping up.
