It is the perforated plate and I try to create a mesh with the points.
When I’m using construct mesh, it has an error message with insufficient vertices.
Here’s my file
Perforated plate.gh (313.7 KB)
Here’s my file
That is not how construct mesh works. You need 4 vertex to construct a quad. To do this I recommend you to use Relative item component. You are using a lot of points and my computer is going crazy but it should work writing this!
Regards!
Perforated plate.gh (313.4 KB)
Your method helped me a lot. Thank you so much!
