Please find the attached file. I am new to paramteric structures, hope so you won’t mind my silly questions. Awaiting your response & thanking in advance
I don’t have time to look at your file today but here’s a short hint: you could try to make your structure nonperiodic. There is a command in Rhino, most probably also in Grasshopper.
there is afaik no native component for makenonperiodic in GH but you can use e.g. a c# component with the following code:
private void RunScript(Surface N, ref object A)
var nurbs = N.ToNurbsSurface();
if (nurbs.IsPeriodic(0) )
nurbs.KnotsU.InsertKnot(nurbs.KnotsU[nurbs.Degree(0) - 1], nurbs.Degree(0));
nurbs.KnotsU.InsertKnot(nurbs.KnotsU[nurbs.KnotsU.Count - nurbs.Degree(0)], nurbs.Degree(0));
if (nurbs.IsPeriodic(1) )
nurbs.KnotsV.InsertKnot(nurbs.KnotsV[nurbs.Degree(1) - 1], nurbs.Degree(1));
nurbs.KnotsV.InsertKnot(nurbs.KnotsV[nurbs.KnotsV.Count - nurbs.Degree(1)], nurbs.Degree(1));
A = nurbs;
I have one more doubt, can the analysis of whole structure (in this particular case, cable, shell, beam, column) can be done by using single command (linear & no linear analysis & IGA solver) or we have to analyse each component separately ?
