just started getting this error this morning. any ideas?
it happens when i try to save a file and i think it is happening on an autosave. the file does save successfully.
thanks.
thanks.
Hi - Are you getting this when you start a new file from a factory-default template?
Please run the Rhino SystemInfo
command and copy-paste the result here.
ok, using a default template still shows the error.
Rhino 6 SR27 2020-6-11 (Rhino 6, 6.27.20163.15081, Git hash:master @ 8c9f18774d0fe24946068d123d78712d7a17f847)
License type: Commercial, build 2020-06-11
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: RGILMORE
Hybrid graphics system.
Primary display: Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 3-9-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 4-7-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-7-2020
Driver Version: 26.21.14.4292
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp "Commands" 6.27.20163.15081
C:\Program Files\Rhino 6\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp "RPC"
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp "AnimationTools"
C:\Program Files\Rhino 6\Plug-ins\Squish.rhp "Squish"
C:\Program Files\Rhino 6\Plug-ins\RhinoRender.rhp "Rhino Render"
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 6.27.20163.15081
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp "PanelingTools"
C:\Program Files\Rhino 6\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp "RhinoCycles" 6.27.20163.15081
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 6.27.20163.15081
C:\Program Files\Rhino 6\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 6\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files (x86)\Seanaptic\64_V6\Seanaptic.rhp "Seanaptic" 5.2.0.0
C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\ColorPicker\6.0.0\ColorPicker.rhp "ColorPicker"
C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\raytraced-materials\0.1.3+v6.15\RaytracedMaterials.rhp "Raytraced Materials" 0.1.3.0
C:\Users\monke\AppData\Roaming\McNeel\Rhinoceros\packages\6.0\SectionTools\2019.7.29+584\SectionTools.rhp "SectionTools"
Hi - what happens when you start in safe mode?
safe mode worked so i deleted:
and it seems to be fine now.
thank you, sorry i should have tried safe mode before asking.
