I am having an issue in uploading a GH file. The system sais I am using a plugin that, actually, I don’t even think to have installed…
Maybe I am missing something or not, please can anyone help me?
If you have saved the file from your computer before uploading it, then you definitely have the Nautilus plugin installed. Now it might be that you have used it in the past and deleted components from the definition, but that some data from the plugin remains.
You could try to use the script I posted here to clean components in your definition: Shapediver uploading failed - Plug in Aggregations by KADAK - #2 by mathieu1
If that doesn’t help, please post a .ghx version of your definition so we can look at all its dependencies.
Dear Mathieu,
I downloaded your definition and found a component which is not supported in ShapeDiver.
After deleting it, my defintion can be uploaded whithout any issue.
Thank you very much for your help!
