Error in the viewport if I print a PDF with a parallel mode - R8, SR14
Hallo, I found a error in the print area.
If I want to print a PDF, at the moment if the view is set to parallel, the viewport remains empty or something is displayed that is not in accordance with what is seen on the monitor.
The situation returns to normal if I switch from the parallel view to the perspective view
I’m currently working with the SR14 and I don’t have the possibility to check if the problem persists with the SR15.
Thanks and best regards
Thanks for reporting, seeing this as well. At the moment you’ll need to Set Window. I’ll get a bug report going. RH-85693
Please try the latest, i was not able to repeat in 8.17
Hello @Japhy, I installed the SR16 and the problem doesn’t seem to exist anymore.
Dear @japhy, after updating to version 8.25 (from version 8.17), the problem has reappeared.
Hi John, can you post the file? Not able to repeat in our latest Rhino 8.x with a box
Thanks
Dear @japhy Strange, whether I’m in parallel or in parallel symmetry projection mode, the view remains white/blank in the print area.
I’m attaching a file for you. Hallo.3dm (1.1 MB)
I saved the view directly in parallel. You just need to go to Print to see if you have the same issue.
Thanks and best regards.
Not seeing it in 8.26, sending you copy.
