I am trying to run a definition to manipulate a model that I have in Rhino and all the nodes seem working well. But when I enable the “model” node, Rhino gives a warning that says “An error occured in the display pipeline. Type: InvalidOperationException”
I am adding a screenshot showing the warning with the node causing the problem when I enabled and the grasshopper file itself.
I would really appreciate it if anyone knows about this.
Thanks!
Gülce
you didn’t internalize your Rhino geometry in the Grasshopper graph and so nobody can check your file
you should mention that the component that you are having issues with is from the tOpos plug-in in the title. Doing this will draw attention from people that are familiar with this plug-in and also ensure that people that don’t use that plug-in don’t unnecessarily spend time looking into this issue.
If the tOpos example file that is available for download from Food4Rhino works fine on your system, you might need to seek help with your issue from the author of the tool.
