Error in text size when reading older file
Hi, there seems to be some issues with reading text in older files.
This file was started in V5 then opened in V6 and worked with, and now the sizes and text data is wrong:
If I select a text object then the properties are allmost all blank:
And if I try to type in a new “Height” then the text is not visible, but I am able to override the setting.
Update:
It is a bug in the way the panel scales, if I make it wider then the data is visible:
Another thing:
Sometimes when I update Scale and hit Enter then the view is not updated, I have to either click in the view or on another setting for the view to update. But most of the time it is context sensitive and updates on the fly as I type. Can’t repeat that bug though.
Can you post a V5 file that shows that scaling problem?
Thanks
