Error in "Save viewport to file" function after last update?
After the last update, the “Save viewport to file” function no longer works correctly. The alpha channel is no longer generated correctly with PNG export and the models are partially displayed moved out of the viewport.
Does anyone have a solution?
Hi Andreas - are you saving the viewport resolution or a scaled version? Does this happen with any file, even a new one with just a box or something?
I have tested every setting, resolution and every kind of format. Always the same result.
