Error in rs Help for RotateObject()
The Help for rs.RotateObject() and rs.RotateObjects() is wrong, it indicates you can supply a plane for the rotation axis, when in fact it wants a vector. Feeding it a plane in this case errors out. I guess one could adapt the rs.RotateObjects() method to extract the Z-Axis of the plane if one is supplied instead of a vector, but currently it does not do that.
thanks Mitch, I added RH-77326 rhinoscriptsyntax wrong info
