Hi everyone,
I have started playing with the new RhinoScriptCompiler.exe provided in Rhino 7, unfortunately, I fall on the following error message whether I build the project or generate the sources:
Rhinoceros Script Compiler
Visit discourse.mcneel.com for answers to your questions.
Compiling RHP Plugin
Generating source for RHP plugin...
Creating project directory:
C:\Users\*UserName*\AppData\Local\Temp\1ad59dc3-8b70-400e-a25c-f7920c32292b\
Writing source code files:
The compiler generated the following errors:
Exception:ArgumentNullException
Message:Value cannot be null.
Parameter name: stream
Press any key to continue
Using a previous .rhc file or creating a new project doesn’t change the outcome of the compilation. Did you guys have this issue? Any idea how to solve this?
Best regards,
Nathan
