I’m having a simple error or issue here I’m just wanting to notify Rhino devs about to make Rhino 6 even better. It’s simply that under the chapter titled Modeling with History, near the bottom half of the page, it’s instructing me to use a fillet diameter of 10 which visibly would work OK… but it’s pushing it VERY close to the objects bottom edge and really pushing the limits of what Rhino 6 can do without errors or creating issues to then be resolved (making the darn thing solid… again!). I use a fillet diameter of only 8 (or less) and it then works to keep my object solid. But 10 is in the level 2 training materials and it’s too much. Here the link for exactly what I’m talking about:
Rhinoceros HelpHello - 10 should work just fine there - can you post your file before the fillet?
I just pulled it to the side using the gumball move, so in case you’re wondering why it’s off it’s wireframe area… cuz I thought that might help, which it didn’t in this case, but it just makes it easier to tell what’s what in the viewport for me that way.
Hello - this is a bug - RH-60428 Filletedge: cleaner if the input is shrunk
If you ShrinkTrimmedSrf
the polysurface before filleting, it works - I’ll get this on the pile, thanks for the example.
BTW, by the book, the side surfaces are single surfaces - you get to set the start point on a revolve, so you drag off to one side, click and then drag across to the other side - this way you do not get an edge in the middle.
Soft Corners5.3dm (670.1 KB)
Yes, Pascal, you were guessing right or happened to talk about why it’s happening. But, not saying it’s not a bug, but yes I did notice that it does indeed work just fine with a revolve surface that isn’t broken up into more parts (even though still exactly the same geometry really). I just didn’t know how to use the revolve tool well enough a few mins ago. But, I’ve figured it out now. Doesn’t matter where you click for revolve angle location… strange, but good. Works like Ortho then. I redid the exercise in that level 2 training section/chapter and found out it does not have an issue when I draw this up in a way where revolves are not split up. Still is an error since the geometry is the same and it looks the same besides it having more things to select.
