I’m running into an error when using my grasshopper code for this surface, it works for other squared surfaces, but not this one. Anyone have any solutions?
Please upload a .gh file with your geometry/data internalized so we can help further.
However, it may be that you are feeding a single value into the Motion input of the Move component and it needs a Vector (composed of 3 parts, X,Y,and Z)
Use the Vector XYZ component, connect your multiplication output result into the proper X,Y,or Z input of that component, then feed that Vec component output into your Motion input.
If your Multiplication output is already in a vector format like (0,0,1) then try adding a “Vector” geometry container between the Multiplication output and the Motion input as sometimes GH gets picky with casting between different data types on certain nodes.
Hope that helps!
