Error in Display Conduit Documentation
I’m looking a the Documentation of the Display Conduit written by @dale
There seems to be an Error.
IncludeBoundinBox doesn’t take a Point3d as an Argument.
How should points be added to the BBox?
Thanks,
Martin
If you have a list of points you can use BoundingBox Constructor (IEnumerable(Point3d), Transform)
if (Points.Count > 1)
                e.IncludeBoundingBox(new BoundingBox(Points));
            else
//What to do here?
//e.IncludeBoundingBox(new BoundingBox(Points));
What does the BoundingBox Constructor return, in Case of only one Point in the Points lists. Will this work?
You may need to define it beforehand.
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_Geometry_BoundingBox__ctor.htm
