Error: "Data conversion failed from Revit Component Type to Boolean"
I am trying to get a closed polysurface from Rhino into Revit. I specifically want it to be as a family so I can use it to cut other geometry. I followed this guide (Rhino.Inside®.Revit) to get the setup, but I am running into an error with the Load Component Family node, saying “1. Data conversion failed from Revit Component Type to Boolean”.
I tried instead of loading the family saving it to my computer and loading it manually, which works perfectly. Not sure what I’m doing wrong. Any assistance would be much appreciated.
System Info:
Rhino.Inside Revit: 1.29.9186.27799 (2025-02-24T15:26:38)
Rhino: 7.38.24338.17001 (Rhino 7)
Revit: 2024.3.10 (24.3.10.22)
CLR: 4.0.30319.42000 (4.8.9300.0)
OS: Microsoft Windows NT 10.0.26120.0
You should try Add Component Node to place this family inside your Revit document
