Error: Data conversion failed from Goo to CrossSection
Hi there,
I’m importing Karamba modules via ghpythonlib.component
not sure how to change the guide of karamba based datatypes.
I did a print check with “CroSec = {}, {}”.format(CroSec, type(CroSec)"
and the data type was printed as “CroSec_I”
script below
import Rhino.Geometry as rg
import ghpythonlib.components as gh
#nodes
node_1 = rs.AddPoint(0,0,0)
node_2 = rs.AddPoint(50,0,0)
node_3 = rs.AddPoint(100,0,0)
nodes = [node_1, node_2, node_3]
#create line geometry
line_seg_1 = rs.AddLine(node_1, node_2)
line_seg_2 = rs.AddLine(node_2, node_3)
#cross section
CroSec = gh.Karamba3D.CrossSectionKaramba3D("beam", "beam_a", None, None, None, None, 30, 100, 100)
line_to_beam = gh.Karamba3D.LinetoBeamKaramba3D(line_elements, None, None, CroSec)
print(line_to_beam )
when I input CroSec to another component or python function I get the following error
the thread here helped me understand the problem but I don’t know how to convert the guid for a karamba “CroSec_I” data type. any thoughts on this ?
thanks in advance !
Hi @keerthana,
try to wrap the CroSec-object before handing it over to Grasshopper. In C# it is
wrappedCroSec = new GH_CrossSection(crossection));
– Clemens
