Error al instalar Rhinoceros 6 con código de error "Redist_vc2015:-2147024893
Tengo problemas al instalar Rhinoceros 6 ; no termina la instalación y me aparece el error
Redist_VC2015:-2147024893; trate de mandar a soporte técnico el doc Rhino_6_20190 y al enviarlo me aparece un Error
gracias!
C:\Users\ALEJAN~1\AppData\Local\Temp\Rhino_6_20190729034607.log
[1330:1788][2019-07-29T03:46:07]i001: Burn v3.11.100.13701, Windows v6.3 (Build 9600: Service Pack 0), path: C:\Users\ALEJAN~1\AppData\Local\Temp{F3685EBE-9E8E-4E25-89E9-9941F7747D2B}.cr\rhino_es-es_6.16.19190.07001 (1).exe
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘BundleVersion’ to value ‘6.16.19190.07001’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘CUSTOMER_NAME’ to value ‘’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘COMPANY_NAME’ to value ‘’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘INSTALLDIR’ to value ‘’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘LICENSE_METHOD’ to value ‘’
[1330:1788][2019-07-29T03:46:07]i000: Initializing hidden variable ‘LICENSE_KEY’
[1330:1788][2019-07-29T03:46:07]i000: Initializing hidden variable ‘LICENSE_VALIDATION_CODE’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘ZOO_SERVER’ to value ‘’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘DISABLE_INTERNET_ACCESS’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘ENABLE_AUTOMATIC_UPDATES’ to value ‘1’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘SEND_STATISTICS’ to value ‘1’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘RegistryRoot’ to value ‘Software\McNeel\Rhinoceros\6.0\Install’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘FolderName’ to value ‘Rhino 6’
[1330:1788][2019-07-29T03:46:07]i000: Initializing string variable ‘IgnoreFolderName’ to value ‘Rhino WIP’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_EN’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_FR’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_IT’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_DE’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_ES’ to value ‘1’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_KO’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_JA’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_TW’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_CN’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_PL’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_CS’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_PT’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i000: Initializing numeric variable ‘INSTALL_RU’ to value ‘0’
[1330:1788][2019-07-29T03:46:07]i009: Command Line: ‘“-burn.clean.room=C:\Users\Alejandro\AppData\Local\Microsoft\Windows\INetCache\IE\954UDIK8\rhino_es-es_6.16.19190.07001 (1).exe” -burn.filehandle.attached=300 -burn.filehandle.self=320’
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\Alejandro\AppData\Local\Microsoft\Windows\INetCache\IE\954UDIK8\rhino_es-es_6.16.19190.07001 (1).exe’
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value 'C:\Users\Alejandro\AppData\Local\Microsoft\Windows\INetCache\IE\954UDIK8'
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\ALEJAN~1\AppData\Local\Temp\Rhino_6_20190729034607.log’
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘WixBundleName’ to value ‘Rhino 6’
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Robert McNeel & Associates’
[1330:1788][2019-07-29T03:46:07]i100: Detect begin, 21 packages
[1330:1704][2019-07-29T03:46:07]i000: OnInitializeLayout
[1330:1704][2019-07-29T03:46:07]i000: PrivateDetect Begin
[1330:1704][2019-07-29T03:46:07]i000: Failed to open license file: ‘C:\ProgramData\McNeel\Rhinoceros\6.0\License Manager\Licenses\55500d41-3a41-4474-99b3-684032a4f4df.lic’
[1330:1704][2019-07-29T03:46:07]i000: GetSystemDefaultLangID() returned 2058
[1330:1704][2019-07-29T03:46:07]i000: GetUserDefaultLangID() returned 2058
[1330:1704][2019-07-29T03:46:07]i000: GetOsLanguage() returned es
[1330:1704][2019-07-29T03:46:07]i000: version_NT64 = 6.3.0.0; service_pack =
[1330:1704][2019-07-29T03:46:07]i000: Comparing ver_64 (6.3.0.0) to ver_win_7 (6.1.0.0)
[1330:1704][2019-07-29T03:46:07]i000: ver_64 !< ver_win_7
[1330:1704][2019-07-29T03:46:07]i000: Showing UI from C:\Users\ALEJAN~1\AppData\Local\Temp{417E896C-07A6-4940-893C-FA41EEF39240}.ba\es\welcome.htm
[1330:1788][2019-07-29T03:46:07]i000: Setting version variable ‘WUAUENG_FILEVERSION’ to value ‘7.9.9600.17415’
[1330:1788][2019-07-29T03:46:07]i000: Setting string variable ‘NETFRAMEWORK45’ to value ‘393297’
[1330:1788][2019-07-29T03:46:07]i000: Product or related product not found: {1EAB0147-B309-466C-BC08-F5516D498BCE}
@brian - The log analyzer could not find a solution from the log text above and suggests sending it along to you. This seems simpler, keeping it all in one place…
@aalmazan this looks like an incomplete log - can you please send another copy as an attachment?
