how to fix this bug?
Hello - thanks for the heads-up. For now, use the English command with an underscore in front:
_Centermark
I guess if you close Rhino and locate the xml file, and open it in a text editor, you can make the change yourself
CentroDeReferencia
on line 87 might just fix it.
@tim - would that do it?
https://mcneel.myjetbrains.com/youtrack/issue/RH-51499
