Error 200 with Rhino main update. Where can I download SR7?
Hello. I had a similar problem a couple weeks ago.
Rhino was asking to be updated to a new release and that was causing Error200 with Rhino Inside telling me it couldn’t launch the license server.
I solved it, but now I got it again…
From the main McNeel page I can get Rh7SR6 (can’t find the SR7 from the automatic update)
I have uninstalled and reinstalled everything several times and Rhino won’t start inside Revit…
Any ideas? Thanks in advance!
Hi Miguel -
You would have to change the update frequency to “Service Release Candidate” for Rhino 7.7 to automatically get installed.
Just making sure - are you running the latest version of Rhino.Inside.Revit (v0.6)?
Have you seen the " Initialization Error -200" section on the “Known Issues” page?
The ideas in the Known Issues don´t apply as (I think) I don´t have Naviate addin or pyRevit.
Can´t I get the Rhino 7 SR7 msi installer? I can´t find the download page to make a clean install and not update it through SR6.
Lat´s time this solution (complete uninstall and reinstall) worked, but not this time.
Hi -
Just change your update frequency and Rhino will offer you the link when you click on “Check Now…”.
-200 is a .net error. Try and launch rhino by itself. Make sure it runs.
Also, make sure rhino.inside Revit is new also.
Is this running on windows server software or desktop?
Rhino 7.7 freshly installed is running perfectly.
Rhino.Inside freshly installed gives error-200 again.
All running in Windows 10 pro desktop.
It was running flawleslly till a few days ago, then Rhino started advising for a new installation again and everything went south.
I now we shouldn´t use it for “production” but I´m conducting a controlled user research experiment for my thesis and I´m desperate… Would sure appreciate an emergency help! :cold_sweat:
Thanks @scottd and @wim . I managed to have it up and running again after installing a couple hotfixes from Revit, so it seems (as expected) there was no problem on Rhino´s side.
Just a small suggestion/wish: would it be possible to identify “visibly” the Rhino.Inside installation files with the release number like in Rhino? I stumbled a couple of times because I hadn´t (unconsciously) properly overwritten a previous download…
And thanks again for the help!!
