is there a way to use environment variables in rhino commands and aliases?
I.E. in windows %USERPROFILE% %APPDATA%.
It doesn’t seem so but I thought I would double-check.
Ciao Guido,
don’t know if you can access directly to that data… a workaround could be to make a script that saves the informations into the file so you can use them when needed.
https://developer.rhino3d.com/api/rhinoscript/user_data_methods/user_data_methods.htm
attached a link where you can find info how to get environment variables in vbscript
