How can the environment become visible in the perspective view and not just in the rendering mode. It is a hdr. file from food for rhino. i tried it with some tutorials… its still working at the tutorials with a click on the pic. (takes over) but not at my rhino… i’ll go crazy -.-
Check the background drop down menu in the Display panel when the display mode you want the hdr to show in is active. Switch it to ‘use render settings’ and it should work like Rendered mode.
Are you using “Advanced hardware acceleration” in Options>View>OpenGL ? The display of an HDR in the viewport is handled by the graphics card in the computer you’re using. The use of it may be disabled or it may be an unsupported GPU or driver. Check this options page next.
I switched my system around to use my Intel HD 4600, using the same driver you are, and set my OpenGL settings to match yours.
I’m assuming you’re using Rhino Render as well.
I can not duplicate the problem.
Have you modified the settings in your Rendered display mode?
Are you running V5 SR12?
