Environment Colors
How to I change the environment so that the walls look white and not grey?
Hi Paloma -
If all walls would look white, you wouldn’t see any difference between the two walls or the floor. I’m not sure how much sense that would make.
At any rate, you can change the “Luminosity” value for the color and material usage on a display mode’s main page.
from the default:
