Net core is the default. It doesn’t make any sense if this is resetting to Net framework. If that is the case, then this is a bug we should try to fix.
Are you experiencing Rhino switching to .NET framework even though it is set to .NET core?
Worth checking with your IT people whether they set the runtime to netfx as part of the push. Possibly to maintain compatibility with some plugin that someone can’t do without.
