The enable disable objects component does not seem to work inside clusters, it “forgets” the objects its connected to when the toggle is changed outside the cluster. Did I miss something ?
Can you provide an example?
It depends how the object is referenced. For example, you can’t use “get connected objects” because… in the cluster it’s not connected to that thing anymore. You’ll need to reference the object outside the cluster to be able to do metahoppery things with it inside the cluster.
