Empty panel bug
I found an empty panel which I expected to display data, and when plugging a new panel, I can see the said data.
Strange…
Hi osuire
Maybe you locked the panel,You unlock to try.
Hi 603419608, indeed, that was the case.
Since there is no “Enadble/Disable” option on panels, I thought that they were just always enabled.
There isn’t any visual cue either.
This puts into light a weakness in the interface, similar to the “Path Mapper” input for which it is not possible to change the wire display.
In Rhino6, disabled panels are drawn differently.
Hi David,
Yes ! Hadn’t noticed…but the right click still doesn’t propose the same options as for other components…
