Hi could anyone help me with this problem? After using an intersection component, my list’s structure which was maintained by ‘nulls’ (->left) is empty now (->right). I tried replace nulls etc., because I can still see the old structure, but I can’t get it back to how it was. Does anyone have an idea? Thanks in advance!
If Japhy’s method doesn’t work for you there’s a “null in empty branches” component in Wombat plugin. Then you can ‘Shift Paths’ to return to initial tree.
Longest List didn’t work for me. Simply adding combine data with one input stream will work however! I didn’t test the wombat plugin, but thanks anyways
