i need to check an array to determine if is empty or not, i thought “isEmpty” was appropriate , but seems to work only on string not on array, and my code return false even the arrTest value is empty.
How can i check that ?
Thx.
Call Main()
Sub Main()
Dim arrTest()
If isEmpty(arrTest) Then
rhino.Print True
Else
rhino.Print False
End If
End Sub
I made some try with Ubound, Like below, but i got error message, i think i miss something.
Just for explanation, i Dim 2 arrays, then i fill one or other in some conditions, in some case , one array still empty , and i need to check that, how can i check the bound of an empty thing ?
Can you just show me how you write that ?
Call Main()
Sub Main()
Dim arrTest()
If Ubound(arrTest) < 0 then
rhino.Print True
Else
rhino.Print False
End If
End Sub
