Emap stopped working in RenderedDisplay
Hi there,
just noticed that when i use the _Emap command while being in Rendered display mode, the object is shown in constant gray color.
If i delete the assigned render material, it shows up. Is this supposed to happen ?
thanks,
c.
Hi Clement -
That seems to work as expected with a new “Plaster” material here, but not with other materials.
I’ve put this on the list as RH-86871 EMap: Doesn’t Work With PBR Materials
Hi @wim, thanks for adding it. Seems that Custom material works too.
_
c.
RH-86871 is fixed in Rhino 8 Service Release 19 Release Candidate
