I have defined a prolate concave ellipse that has been sliced in half horizontally, like an egg, and the bottom half I have discarded, leaving only the upper half of the ‘egg’. I want to create a workspace where I can draw a figure-8 that will automatically be mapped to the upper surface of the ‘egg’. I don’t want to use the Project cmd because it will distort the figure-8. I have been unable to create the workspace. I have the reference ellipse perfectly created and sitting in its own locked layer. But what are the steps to replicate that curvature to my workspace so that when I draw the 2D figure-8, it will conform to the curvature of the reference ellipse?
Hi @William_J_Stroupe
When asking for help, make it easy for people to help you: Preferably post a 3DM-file with what you have so far, or at least sketches or screen grabs - basically anything that will describe what you are looking to achieve and why it’s causing you trouble. Although written for Grasshopper, there’s a lot of sound advice on how to best explain your issues to others in this post:
Here is the 3DM file I am using. The problem I am having is that I have tried various methods to get my coil_path_2D layer (my workspace) to contain the identical path of my reference ellipsoid that is on the locked layer - but none of the methods so far have succeeded in creating that duplicate path into my workspace layer. So far I only have succeeded in creating the ‘spine’ - the vertical line in the top view which is the right edge of the sliced ellipsoid. If you click on that ‘spine’ you will see that it does represent that right edge of the sliced ellipsoid. But how do I get the rest of the reference ellipsoid path into my workspace, so that when I draw the figure-8 coil, it maps to the 3D curvature of my reference ellipsoid? Thankyou Jakob for your suggestions on how to make this post more informative.
I have my workspace created, but when I draw using InterpCrv, or InterpCrvOnSrf and select my reference ellipse as the surface to draw on, I am allowed to place points anywhere in free space - my points should be conforming to the ellipsoid surface, and they do not. So the resulting loop I draw never intersects with the reference ellipsoid surface. Is there another workflow / command I can use to ensure that when I create points they will conform to the reference surface?
Actually - I think I was relying too much on the viewports - I did an analysis on the difference between the loop I drew and the ref. ellipse and the analysis came out so close to perfect that it may as well be called perfect - the avg. deviation between my drawing and the ref. ellipse surface is only about 3nm. So For now I think I have solved my problems. But I wish there was a way in Rhino to rotate the perspective and other views in the 3D space - that would make it much easier to see if confomity between ref. and drawing exists.
That black trace that is not selected is a previous attempt to draw on the reference surface - it failed to conform at all. The selected trace does conform almost perfectly - but in the Perspective and Front views it doesn’t look conformative - but it actually is. I think if these views could be rotated in 3D space it would become more obvious that the loop I drew is indeed conforming to the reference surface.
