I’m using elk road with is not coming only single line coming. How to get actual road width as it as Google map any help.
Hello sailor!
Curves don’t have width. You can assign a width to a curve by changing the print display property in rhino but only for representation purposes.
Google earth uses JSON format to assign a determined style to the geometry on the map, but you can’t do that in Rhino nor Grasshopper.
A good approach would be to offset the curve using the offset component and asigning the actual value of the road.
Best regards,
Sir Ernest Shackleton
