Hey,
When you are using the Lunchbox plugin’s “Hexagon Cells”, it’s better to enter an even number of U or V inputs depending on the U or V direction of your target surface to match the pattern at the seam location.
Nonetheless, you can’t remove seams from the Hexagon cells that are present on the target surface seam. It’s a bit annoying, but you’ll have to find them separately and remove them.
RemoveHexaCellSeams_re.gh (17.3 KB)
