Eliminate specific coordinates
I would like to be able to eliminate these specific coordinates when they jump by 100 I I want to delete that point and the two adjacent points … don’t even know where to begin, please help … TYIA
eliminate specific coordinates.gh (9.9 KB)
I think this accomplishes your goal.
240507a_eliminate_specific_coordinates.gh (11.2 KB)
Includes option to cull the points or replace them with nulls.
Point and Expression components show errors because your input list contains nulls but they still work as expected.
-Kevin
thank you @kev.r that works great the one issue I run into is if a point is a little off … how do we tweak it to round to the nearest whole number before removing the lines? Thank you so Much!
Added round(x,0) expression to Point component. I think this should address this issue.
240507b_eliminate_specific_coordinates.gh (11.3 KB)
-Kevin
@kev.r … Next I’d like to gather all the distances between the points on either side of the higher point then total the length of those points … can what you created be modified to do this or is it an entirely different process?
