Elevation markers and annotations recommended workflow
Hello and beatiful day to everyone :slight_smile:
I am in the middle of evaluation of VisualARQ and will definiitely buy full version in the end, but still sovling some basic issues so bear with few weeks to ask some questions.
Anyone willing to share your best workflow fo annotating and mainly level placing level markers?
What I am trying to solve:
  • my main workflow with other softwares were 3D for model and layout for dimensions, level amrkers and annotations, in VA and Rhino it is almost there with live floor plans and sections
  • annotations are not so big issue - I can draw over detail in layout space or directly in 3D based on the needs of specific annotation
  • but I dont like workflow with elevation markers - I need to place it in 3D space right? and that is not any good because it clutters 3D model with lot of unnecesary geometry and I need to make lot of layers for these for every drawing (foundation section, whole building section, roof section) to separate them and turn them on only in specific detail)
  • one best solution for me would be possibility to place elevation marker in layout space over detail and if I snap it - it will read correct coordinates of that point in 3D model - but that dont work
So how do You solve it? are You placing all elevation markers in 3D space? anyone have solution to place these markers in layout? I also tested vaSectionView command and for a while it looked it could work but really dont like that 2D block in 3D space workflow.
Your workflow and tips appreciated here :slight_smile:
Thanks Martin
Hi @TwinPlan_MDa, we need to make it possible to insert annotation objects (including those created as a Grasshopper Styles, like the Elevation mark) in the Layout views, on top of the details, and detect the coordinates.
Until this is no implemented, you can manage their visibility by Layer in each detail viewport. Not the ideal workflow, I know, so I hope we can improve this soon.
This will solve this problem really, to add markers and annotation from layout and behave like classic dimensions, which “reads” 3D model.
So I assume i have correct workflow now to put those in the 3D view and manage by layers. Nothing better till You can implement mentioned before. Hope for that addition soon :slight_smile:
Regards
My typical worksflow with these is
  1. Create a section view on a separate 2D-file (worksession the 3D-file). This keeps the original clean, and you can really easily update the “drawings file”. Sectioning a worksession has the added benefit that you’re are not tethered to the original layers anymore. In printing it does not matter which layers you have ON in 3D anymore.
  2. Position the section view so that Y in the plan equals Z in the model. (This needs to be done after the sectionview is created as the section view origin is NOT in the location where you place it. @fsalla )
  3. Create an elevation marker that gives the Y-coordinate, or sometimes I use Rhino’s Ordinate dimension (Create a metric-style, 3 digits resolution, and a ‘+’ Prefix.
Interensting - I will definitely try this :slight_smile:
Toni, nice!
So far i used in layout rhino dimensions that work as expected in layout mode, as also like you ordinate dimensions for levels. Thus, model space is kept clean.
It would be nice if VA annotation objects would also work in layout (and or any other solution) because not only dimensions and levels float in model space, but also door window tags etc.
The Dim Ordinate works without doing the worksession process too. Just cut a section through the model and DimOrdinate. But be aware all dimensions will be absolute heights from the internal 0,0,0 and not tied to any construction plane or building level unless you select a point each time to overwrite it. Which would be crazy tedious.
Absolutely agree that annotation objects (like tags and so many other things) in the layout views instead of the model will be great.
I foun dout, that Dim ordinate does not suit my needs as @Toni_Osterlund showed in video. I need to show minus sign for levels lower than 0,0 so I need to stay for level markers palced in 3D space for now. I hope, that VA or Rhino itself could solv thsi issue soon.
@TwinPlan_MDa
You are probably aware of these VA annottation style examples:
https://www.food4rhino.com/en/resource/level-reference-elevation-mark
Maybe you find an interim solution from there, as waiting for the Layout version. BTW, ordinate dims work in Layout views as well, as long as you snap to geometry in the model view.
I think it is a downright bug that Ordinate dimension does not display negative values (@wim).
[Edit: also it would be really useful if one could define ordinate dim with an arrowhead. Then it would be possible to construct elevation symbol with Rhino objects directly)]
You can add a minus sign manually to the dims below zero. Either replace the prefix, or add “-<>” in the text fiels.
One noteworthy thing with ordinate dimensions are their copying. If copied as an object the base-point moves with the object. They need to be copied by the control points for the value to update.
