Hello, some elements disappear when i try to copy it
Hi @Henry_Boutet_de_Monv we are still investigating about this issue. If you save the model, and open it again, you will see the objects copied.
Hi @fsalla, I don’t see objects copied when i save and reopen, that make also that with windows roof
roof bug.3dm (5.9 MB)
And also with the grasshopper zinc wall
Hi, I have same issue with elements missing. Using Visualarq 3.0.13.19113 and same problems with Visualarq2.
Hi @Henry_Boutet_de_Monv got your file! If you selec the walls and update them, they should be back!
@Magnus_Strand can you share a file to revise your case?
Hi Francesc, thanks its work
@Henry_Boutet_de_Monv @Magnus_Strand I’m glad to inform you that this issue has been finally fixed in VisualARQ 3.2 version, which already available to download: VisualARQ 3 - Version 3.2 released
I’ve still had a couple of issues with elements disappearing. I think its when I press escape before copying an item. There must be some function that solves the problem that is not executing if you press escape before completing a copy. Reloading the grasshopper function solves the problem as it did in previous releases.
@Benjamin_Paolo_Fortu are you using the 3.2 version? can you reproduce this error? please share a file that we can test to reproduce this as well.
Thanks1
I an using the 3.2 version. I’ll let you know if it happens again.
@fsalla , i try with version 3.2. but i have again the problem with roof windows
FEFENE.3dm (2.3 MB)
Hi @Henry_Boutet_de_Monv we are aware of this bug. We will fix it as soon as possible. I’ll keep you posted!
Just to let you know, the issue you reported where a Roof remove all hosted windows except the last one inserted no longer occurs.
(You may need to update the geometry using the _vaUpdate command to ensure all layers display properly.)
You can read the update in the release notes here: VisualARQ 3.5 - Release Candidate 5 is now available for download.
