Elements created with the Revit module that do not appear in Revit
When I try to create a wall using the “Add Wall” component, it does not appear in Revit. The curve appears correctly, but not the wall. I’ve watched several videos where they simply use this Grasshopper script (screen), and the wall appears in Revit. Is there a specific option that needs to be enabled to allow the creation of the wall in Revit?
I found the solution: I selected it by its ID and had to change its creation phase to “Existing.”
