Elefront beta problem on filter by user attributes
Does any one have this issue?
filter by user attributes never works on beta version :frowning:
@newshunhk – can you provide more context to the error or difficulties you are experiencing?
@newshunhk i felt like procrastinating a bit and decided to think what may be the issue and I am pretty sure it is because you are mixing and matching the v4 (old) and v5 (new) components. The v4 attribute object is not compatible with the v5 attribute object. This means that when you try to pass an v4 attribute object into a v5 filter component that expects a v5 attribute object, you get an error. I think the error message could be more clear and will think about how to clear that up. Below is an image of what the expected behavior is.
  1. v4 attributes going into v4 filter component – works as expected
  2. v4 attributes going into v5 filter component – throws error as expected
  3. v5 attributes going into v5 filter component – works as expected
  4. v5 attributes going into v4 filter component – doesn’t work, but doesn’t throw an error as the v4 filter component just ignores the v5 attributes because it doesn’t know what to do with them.
Hope this clarifies!
thank you! so detail explain😀
yeah…I think I am reading the baked geometry by v3 or v4…using v5 beta
thanks!
