Elefront Angular Dimension Bug 🐱‍🐉
I just want to report a bug on the AngularDim component of Elefront. It doesn’t work when the angle is exactly 180 degrees. I guess it is because it can’t tell which one is the angle to be flipped. If you change the angle to 180.0000000000000001 degrees it works.
Just fyi in case you want to fix it and didnt know about it.
Isma
