Elefront 5.1.1 - Object reference not set to instance of object
Simple bake test
Same issue here… Legacy bake works fine
@michaelvollrath this was addressed in another thread. Should be fixed in 5.1.2
Thanks for the response @elevelle !
Unfortunately, 5.1.2 is the version I am running and still returning the error.
Two questions:
  1. do your trees match?
  2. do you have any null or bad objects you are trying to pass?
Those two issues represent 99% of the problems.
If you want, you and DM me your definition and someone will look at it.
@elevelle There was null value in the list, clean tree sorted it and now it’s baking fine.
Thank you!!
Did legacy bake accept the nulls?
If i recall yes, but was a good vector for error so…now it fails.
Makes sense, thanks again for the help
