An idea may be useful to create electrical tables using windows styles
Hi Jon,
It’s a bit weird to use the window object for this electrical point (rather than the Element object), but it makes sense since you need it to be hosted in the wall. I think we should make the Element objects to be hosted in walls (or other objects) as well.
The opening elevation command doesn’t work with windows created with blocks or from GH styles, but this is fixed in the upcoming 2.6 version.
+1. This would be quite useful.
